1999 P71 Won\\'t start
Thread Statistics:     Users to Post: 3   |   Total Posts: 3   |   Total Views: 1457
hsnorider
• Boise, ID, USA
• Registered on 6/30/2012
Posted:6/30/2012 12:07
I have a 1999 Ford CVP P71 that died while driving down the road. The starter cranks like normal but the car wouldn\\'t start. On closer inspection all the fuses and relays both under the hood and the dash are good, But there are two brown wires in the ignition switch wire harness that do not have power in any key position but when I jumper them to a \\"live\\" wire the car starts and runs like normal except when I turn the key off the car keeps running until i pull out the jumper. Any Ideas would be great thanks.
wizzard1222
• Ballwin, MO, USA
• Registered on 1/27/2011
• 139 posts
Posted:6/30/2012 13:03
Sounds like you are @the point of the issue....
Are the two brown wires part of the ignition switch...?
Is there any indication where these two brown wired trace to/from that is replaceable...?
Have you checked the OBD2 codes...?
Posted:6/30/2012 14:22
If you do not have a Chilton or Haynes manual to look at the wiring diagram, try this link: http://www.cb7tuner.com/vbb/showthread.php?t=147239
I haven't looked at the 1999 version, but I suspect that you have a bad ignition switch. You said you put a hot wire to the 2 brown wires in the switch. That is what leads me to believe the switch itself is bad. I'm not talking about the ignition lock that your key fits in, but the actual contact switch in the column. Hope this helps.
